I believe my Basic code is correct. According to examples that I have looked at it should work...
MsComm1 settings, code, etc...
Dim all avriables and constants regarding DF-1 protocol in a public module, etc...
(I can provide upon req.)
I am trying to read the N7:0 file and write to the N7:1 and N7:2 files of an SLC 5/03 via a direct RS232 connection. I have MOV set up in the controller logic to move the data from the input files to the N7:1 and N7:2 integer files and interger file N7:0 to the output file.
What I have noticed:
1) I can run the SLC program and it works fine.
2) I can run the VB script without errors.
3) When I use RS Logix to edit the SLC, the RS232 LED on the CPU card "bleeps".
4) When I execute my VB program, the RS232 LED stays unlit - no comm?
Did I forget to set something in the SLC programming? My VB code bad?
Ugh!
Any additional input is appreciated!!
jMk
Ugh!
jMk
