I
While starting the gas turbine, after applying the start signal the diesel engine starts. Initially for 2 minutes at 600 RPM then on the energization of 20DA-2 SOV, the speed of diesel engine goes to 2100 RPM. At the speed of about 2900 RPM gas turbine takes over the control and diesel engine disengaged from the Turbine.
At speed 2100 to 2900 RPM, does the diesel engine rotate either at its own maximum speed 2100 or with turbine speed 2900 RPM?
If it rotates at 2900RPM then we can say that gas turbine takes over after 2100 RPM which is the maximum speed of the diesel engine but disengage at 2900 from the turbine. What is the function of torque converter in all this activity?
Gas turbine frame 5, capacity 25 MW, diesel engine makes/ model, Cummims HP 465.
