Digital Panel Meters
RK Sastry
We have been using a number of SIEMENS Make Digital Panel Meters (some with potential free contacts or relays for alarming) of size 96X48. I give the Mfr. Part number for your reference: 7NJ3015/3016. These meters are obsolete now and I need any suggestions for replacing them. Since these are used on a Mimic, if possible same dimensions would be ideal.
In the US, those are known as 1/8 DIN panel meters which designed to fit in the same panel cutout as you have. But the exterior bezel sizes vary depending on the vendor.
There are numerous vendors, so you'll just have to check out whose bezel size is the best replacement fit for your panel board, and then match input and alarm functionality.
