Dears,
We have a problem with a GE heavy duty frame 5 turbine, MKV control system.
During crank stage at 2200 rpm in starting diesel motor, turbine shaft remains stopped, We had place one manometer for read pressure in charge pump discharge, the pressure is 4,8 barg.
We replaced torque converter-hydraulic clutch assembly, but we got the same results.
Any suggest?
Thanks in advance
Any suggest?
Thanks in advance
