K
I've just realised that M registers can't be controlled via MODBUS and %M00200 is the toggle bit between MODBUS and SNP in the logic. The problem is that I can read and write MODBUS perfectly but you can't program or attach via MODBUS... Is there any way to clear/stop the PLC or change the protocol back to SNP? I know there is a pin 4 on the PLC programming lead which is used by a GE programming unit to set the port back to SNP but I have no idea what the PLC requires on this port (I have tried grounding it and pulling it up to +5v with no result).
