G
I was hoping someone would be able to answer this question for me. I work at a production plant and we have three G.E. steam turbine generators. Units 1 and 2 are rated at 12,500 kva and unit 3 is rated at 25,000 kva. Each generator feeds a separate bus that ties into the grid. My question is this, we want to close a tie breaker that will basically tie units 1 and 3 onto the same bus, putting them in parallel. We will be running unit 1 at 5 MW and unit 3 at 10MW (still on the grid). However, in the past when we have done this the two generators have 'fought' with one another. Everyone seems to have a different opinion as to why. I believe that we need to run each of them at the same line voltage (about 13,200-13,400) but when we have the line voltage the same the power factors are different. I believe that we need to adjust the reactive current compensators' to make the power factors the same. Am I wrong? Thank you for any input into this.
