G
I'm looking for a sensor that can measure the height of product from 0-52 inches. Resolution would be ideally +/-0.10 at least. The data feed would go back to a DAC in a PC. I'm more concerned about the sensor than I am the rest as I can tailor to meet the needs at hand.
The application is to measure the load height on a pallet to ensure that the correct amount of product has been placed on it. If the resolution were high enough, it could even be used to estimate the count on the pallet.
I haven't seen a sensor that can do this large of a size without doing some kind of array, but I've been out of touch for a while.
Any Suggestions as to what I should look at?
