Help with load cell accuracy
H
hasala
I use two 100Kg load cells with accuracy (0.02% FS) with one indicator. Maximum permissible error is 80g (from the analogue retransmission (0-20mA) to PLC).
(The stated error was not for indicator but to PLC input.)
I used Gefram 40B 96, it gives an error over 200g.
How can I achieve the required accuracy? What kind of a cost will I have to face? Is this accuracy achievable in an industrial environment? We are measuring weight of tea in hoppers. Load cell is sartorius.
Urgent help will be greatly appreciated as I am completely stuck.
hasala dharmawardena
hasala at ieee dot org
What type of load cell is used? Do you use a summing box to match the signals of the two load cells?
The stated accuracy (0.02%) - is it at constant temperature or over a wide temperature range?
Sam
