I have a serious problem with my lCN. a cable suspect occur very frequently on cable A only. i visually checked all cables, connections, cable ground. I also measured EMI in the control room. The emi level is quit high near one network end. Can the EMI affect one cable only? Also I noted that when i unplug then plug one termination on the suspected cable, the problem disappear instantaneously...!
any help?
thank you.
any help?
thank you.
