I understand that during a compressor surge air will flow in reverse direction out of the compressor …the engine power generation cycle is basically interrupted and the engine is no longer producing power besides the very detrimental /damaging effects of the reverse flow on compressor components.
I can't not understand compressor stall phenomena, however !
what does exactly stall do to the compressor and air flow ? does it cause reverse flow ? does it cause air to be trapped inside compressor casing and just keep moving or rotating but does not exit ?
The explanations for this topic I found on the internet or in book is a bit advanced to me.
