I need software to program a siemens simatic plc ti305
E
Eduardo Garcia
Please If someone knows what software can I use to program a Siemens TI 305 PLC, and also if there are some demos to download or shareware software.
Thanks.
Eduardo Garcia Mondragon
Tridente Electronica S.A de C.V.
Av. M=E9xico 505-1, Col. Am=E9ricas, Toluca M=E9x.
Tel/Fax (017) 2-17-93-95.
If your Simatic TI305 was manufactured by Koyo and similar to the GE Series One, you should be able to get the software from Direct Automation.
Try www.automationdirect.com for part #PC-PGM-305. Depending on which CPU you have, you may also need an RS232 adapter Simatic PPX:305-03DM, or Automation Direct D3-232-DCU. Rather than buy one of these, you might be better off replacing the CPU card with one having an RS232 port built in.
