I have added a java client to the LPC and fixed some additional telnet problems. The new java client can be accessed at
http://148.61.36.72
The telnet problems that I fixed seemed to be unique to those who used the Microsoft Telnet Client to call in. It seems that the Microsoft
client sends out characters as fast as they are typed, instead of all at once after a linefeed. This may also explain why when using telnet from
windows it seems sluggish, it is spending alot of time trying to transmit single characters. If you are using windows to access the client, I suggest you use the Java client instead. (if you want to use MS-telnet, you will need to play with the settings to make it happy.) You can get telnet access with, telnet 148.61.36.72 1237
As always, feedback is appreciated. If you need more information about the LPC you can get it at,
http://claymore.engineer.gvsu.edu/lpcd
Thanks,
Hugh
LinuxPLC mailing list
[email protected]
http://148.61.36.72
Thanks,
Hugh
[email protected]
