Let’s say I have a prox switch and a solenoid valve mounted on a 10’ steel pole in a field. The steel pole is bounded to a good earth ground and the control power for the prox and the solenoid is from an ungrounded 24vdc power supply. The prox is an input for a PLC and the solenoid is an output. Now let’s say the pole is hit by lightning, being that there is on earth ground connected to the prox or the solenoid. Does my PLC live? Does the prox or the solenoid live? Would lightning protection on each I/O point help or give a different outcome?
To me seeing as there is no reference to ground back to my PLC. Why would current flow back trough the wires from the prox or solenoid to the PLC?
The PLC and the 24vdc power supply are powered by 120vac source and they have their own lightning protection.
