Hi all,
We’re evaluating a 4-unit liquid ring vacuum pump replacement for crystallization cooker NCG extraction, and I’d like to get practical field input on reliability.
Quick specs
My questions
Quick specs
- Application: crystallization cooker off-gas, saturated humid air
- Dry air flow: 104.2 kg/h
- Water vapor flow: 57.9 kg/h
- Total inlet volumetric flow: 1322 m³/h
- Suction pressure: 100 mmHg(a) / ~133 mbar(a)
- Discharge pressure: 760 mmHg(a)
- Speed: 975 rpm
- Construction: stainless steel casing, rotor, shaft
- Seal type: braided packing
- Supply scope: bare-shaft pump
My questions
- What are the top root causes for repeated impeller wear in this wet, crystal-carrying gas service?
- How do you approach stainless steel material selection for rotor, shaft and casing here?
- What operating data is most critical when sizing for saturated air + high water vapor load?
- For cavitation risk at ~133 mbar(a) suction, what do you check first?
- What inspection or monitoring practices reliably extend long-term service life?
