Thanks Curious_One,I am thinking to just test them using function group sequence, i will just change the primary Jacking Oil Pump (JOP) so that when i start the group the primary pump JOP will start. What are your insights about this? This is to avoid controlling it manually
If the HMI will allow it, then go for it.
Good day ,I am thinking to just test them using function group sequence, i will just change the primary Jacking Oil Pump (JOP) so that when i start the group the primary pump JOP will start. What are your insights about this? This is to avoid controlling it manually
Hi CSA and Curious One,
May I just ask what is the function of below button highlighted in yellow?
Never the less, if the turbine is offline. Feel free to click on buttons. If the boiler is offline, and steam pressure is not present one can do very little to cause problems.
Please locate and refer to the operations manual for the turbine/hmi provided by GE.
This is the best I can do with the information I have obtained from you thus far. It is also the best I can do in my current mood.
HiI am thinking to just test them using function group sequence, i will just change the primary Jacking Oil Pump (JOP) so that when i start the group the primary pump JOP will start. What are your insights about this? This is to avoid controlling it manually
| G | ALSTHOM C10/120-M2 TECHNICAL MANUAL | Power Generation | 0 | |
| B | GE Steam Turbine manual Trip Buttons | Power Generation | 5 | |
| S | Speedtronic MARK IV Manual | Power Generation | 6 | |
Supcon JX-300XP configuration and maintenance Manual | General Automation Chat | 0 | |
| M | Device for manual "takeover" of 4-20mA signal | General Automation Chat | 2 |
