Done but it is not working yet
Done, but there is not response from the converter. And if I put Unit ID as 1, the mo
I've enable it, but there is not response from the converter. And if I put Unit ID as 1, the modbus LED stops blinking on the HD67673
| Thread starter | Similar threads | Forum | Replies | Date |
| P | Direct Barcode, 2D & OCR to PLC via Modbus TCP (No IPC or Middleware Required) | Modbus | 1 | |
| B | BACnet to Modbus integration | Modbus | 3 | |
| C | MODBus TCP to BACNet IP Gateway Using v6 IP addresses | Modbus | 2 | |
| S | Water/Gas Meter with Modbus/LonTalk/BACnet Compatibility | Modbus | 1 | |
| L | Modbus 2 Bacnet Convertor | Modbus | 16 |
