F
Hi everyone.
I need help about magelis screen XBTGT 2230 and Vijeo designer. I'm trying to use modbus RTU on COM1 or COM2. The unit I'm trying to communicate with doesn't have continuous register. In the modbus setting I have try to put the preferred frame length to maximum but the gap between register are to short (below 24) so the unit response with faulty frame. If I put the setting to minimum the communication is too slow (1 register at the time). We have try to make different equipment to make different group, but we can't assign ID:1 to different equipment, vijeo designer can't build the program. May be somebody have a solution for us ?????
Best regards,
Frederic
Best regards,
Frederic
