here the system architecture
[IntouchWW-FSgateway-MatrikonOPCforModbus]----by Ethernet----Floboss S600 (flowComputer)
for specific duration the matrikon run perfectly, the values are updated but in random time the matrikon will stop update value from floboss S600. the floboss is still running and OK. the only problem is in matrikon. and if i try to open matrikon explorer, its not responding.
so far the solution i did is go to task manager and kill this process "OPCMODBUS.exe" and the opc clients run perfectly until the same problem come.
thanks
note: matrikon is licensed, is not trial version
thanks
