I have a Keb Inverter all Ok when electronics test. but when i install full setup and run the Injection Molding Haitian Machine the machine seen OC Error. How to solve.
It's taken that this is a variable frequency drive (VFD).
One incident some years ago related to another drive tripping on overcurrent (OC). The mechanical engineer said it was an electrical fault - the control engineer examined the fault codes on the VFD and stated the drive was protecting the motor from overcurrent as the machine bearings had almost siezed ! [from lack of lubrication].
It would suggest here that your Molding Machine has similar mechanical difficulties.
