Hi.
I have a solar system that utilizes a PLC to control hydraulics that move the panels as per the Time of Day. There is a lever that turns a linear POT based on the position of the panels, and based on its resistance, and the Time of Day, the hydraulics move the solar panels.
See pics below.
The Time in the PLC was slow, and the person who normally maintains the solar system is gone. I have tried changing the Time (via Termite Software), but have been unable to do so. I changed the battery in the PLC as it was 12 years old, and as a result, the Date/Time got zeroed. I don't know how to get the PLC into programming mode to allow me to enter the correct Date/Time.
The company that sold me the system is defunct. There are no markings on the PLC. I am looking for a replacement PLC that I can program myself.
The inputs are 12 VDC 5 amp, and 3 wires coming from a single turn, wire wound, Linear POT from ETI systems.
The 3 outputs control three 12VDC coil relays (hydraulic pump (120VAC), CCW hydraulic control valve (12VDC), CW hydraulic control valve (12VDC).
Can you help me find a suitable PLC ?
Thanks,
M...
See pics below.
Thanks,
M...
