V
hai,
we had a problem in ratchet, where the sequence is coming continually. due to that we change the both with new one, filter and the 20cs-1 and the sequence valve. but again the same is action were we just now completed our MI. after that we facing lot of problem in ratchet while first start up. we can't able to ratchet it, can't able to rotate the shaft then we change the voith mechanism with new one. after that it able to rotate the shaft. but the sequence is it engage with the shaft and rotate after 45 deg it come fully disengage and comes out after the time again it engage and rotate.
after this went for 1 hrs. after that the ratchet come in a continues one. please let me know the port operations of the sequence valve and the related materials. please send me the link.
<b>Moderator's note</b> Punctuation in the first paragraph of this message is mine. There were no commas or periods.
