W
I need software to connect PLC Telemecanique TSX47-10 & PL7-2/TSX17 to PC to monitor the PLC input & Output
Also, I need the connecting cable configuration
Here's a link to the com cables diagrams.
http://sylvain.marsol.free.fr/archi...seaux/caracteristiques_des_cables_par_SCT.pdf
There are quite a few cable options to use depending on the PC setup you have and the PC you have.
The software is X-tel, but I don't think you can run it on Windows. It must run under OS2. I'm not sure if you can run it on Virtual PC or something else. I still have the FTX 507 laptop that runs OS2, so I don't have much information how to connect using later equipment.
A | connect with Twido Telemecanique PLC | General Automation Chat | 0 | |
A | Dimensions of Telemecanique CPX 37 Operator Panel | General Automation Chat | 0 | |
C | Telemecanique TSX 17 | Programmable Logic Controller - PLC | 0 | |
C | Telemecanique PLC Battery Dead | Programmable Logic Controller - PLC | 0 | |
S | Telemecanique TSX 17 | Programmable Logic Controller - PLC | 1 |
