Please need somebody to clarify the Turbine Compartment Pressure. our turbine frame 5 mark 6 . there are two protection in the Turbine Compartment Pressure and Temperature . did the system work with pres. or temp.
What is the pressure measured in this room is it for the fan with the turbine compartment or turbine compartment pressure with atmosphere. the unit i see mmh2o ?
Thank You
Thank You
