I am looking forward to implement PID for water tank level control using Microcontroller.
I am facing difficulty to select sensors & components related to it.
To measure tank level i can use ultrasonic, hydrostatic pressure, capacitive and float sensor.
I can collect data for tank level into microcontroller from above mentioned sensors.
But i do not have much idea about following sensors :---
1> Sensor to measure water feed out of the tank ?
2> Which feed Valve to use to feed water into the tank ?
Suggest something which i can control using microcontroller ?
3> Also can solenoid valve can be used to control water feed into the tank.
Please try to suggest some less expensive sensor for which i can write control software in microcontroller to make an efficient system.
Please suggest on above points.
kind regards,
allan
kind regards,
allan
