110 vdc solenoid valve
Hi
I have a 110 DC solenoid valve, so when I checked the resistance of the coil, I found it around 0.8kohm, Is true to be within such a range, although the coil works good.
In addition, how to know the resistance of a coil from the data sheet, I'v searched and didn't find anything.
ZiadAlwr
If the load is resistive then measurement proposed above is adequate. But if the load is inductive then current will be less! I suggest you measure temperature of the coil!
Regards, Phil Corso
