So we need to get feed from 125Vdc for 110Vdc, from new battery charger and remove the old ones. Any ideas how to do that?
Umairabbasi
Welcome to Control.Com!
Q1) Do you mean you need to provide a 110 Vdc Load from a 125 Vdc Source?
Q2) Are the Negative side of both Load and Source grounded/earthed?
Q3) What is the maximum Amperes of the Load?
Regards, Phil Corso
| J | UL508A - Disconnect switch for 12Vdc battery | Electrical Engineering | 1 | |
| S | ?How to control 24VDC solenoid using 12VDC relay & separate power supplies? | Electrical Engineering | 1 | |
| T | UL508/UL508a 12VDC System | General Automation Chat | 1 | |
| D | 12VDC Motor Controller | Motion Control | 3 | |
| A | 12Vdc motor control | Motion Control | 5 |
