ABB OS500 HMI Operator Station AC450
Hello.
We have network of 14 ABB AC450 PLCS and 04 Nos OS500 hmi/operator stations with WinNt 4.0 and AdvaCommand Software.
On 1 operator station, some specific events text appears as green in color while same events appear as alarms in yellow color on other hmi/pcs. See attached picture. The last 4-5 alarms in both pictures are same but different color.
I have checked the rta file on all pcs and related event no configuration are same.
Wt other configurations i have to change.
Any help apperciated
You could post this question in oru ABB open user forum, this is moderated by ABB experts and customer users can contribute: https://forum-controlsystems.abb.com/
For our control system customers, we provide access to detailed information including manuals and support in our customer portal "myABB" after registration. To get access, please contact your local ABB representative: https://new.abb.com/contact-centers.
Also please directly contact your local ABB service if you face severe problems so we can investigate the root cause of the issue.
Matthias Stein
Marketing Communications Manager
Process Control Platform
ABB Industrial Automation
Thanks for your kind help Matthias.
I will follow your suggestions, meanwhile i have come up with solution by reading ABB Manuals although not practically applied but i will goto Abb forum.
Thanks.
In case you still require some support here with the following options:
-suggest you try to retranslate the object references from the OS520 that shows the alarms wrong (maybe not for the whole network but just the specific 450 node the signals come from)
-check which machine is the Alarm Event Server as some alarm appear to come twice
-check time synch of the system (that all show the same time)
Happy to help further if you need more info.
Best regards
Stephan
