Gas Turbine Frame 9E has been installed at our combined cycle power plant. This machine runs on both fuel gas and fuel oil.
In fuel oil system loop, an electromagnetic clutch is installed between shaft driven main fuel oil pump and accessory gearbox. To continue a co-firing operation, command is going to engage the clutch but it is not engaging and the pump does not turn ultimately GT trips on low flow signal and turns back on fuel gas. We have checked the input command signal of 125 VDC that is going to clutch.
Our gas turbine frame 9E unit is now running on fuel gas so we cannot perform the internal inspection of the clutch before any outage.
I am attaching a P&ID. Can we have a discussion on it how can we resolve it.
