We have ABB Tank level indicator. Model No. Datum U110. we are receiving System error in the display. We switched off the power and started again the same error exists. What does it mean?
Me too. What the solutionsWe have ABB Tank level indicator. Model No. Datum U110. we are receiving System error in the display. We switched off the power and started again the same error exists. What does it mean?
System faultLets tell us if you have read the OEM manual??
I got one but there is poor informations on alarms/faults description...
Can you tell us what is the error /fault message that you read/got ?? is it displayed on LCD screen of the device?
Is there any other controls system associated with device such as DCS/SCADA...
ControlsGuy25.
is that written as "System Failed " it is or as you wrote "system fault" which is bit different .System fault
So what is the password of the deviceis that written as "System Failed " it is or as you wrote "system fault" which is bit different .
OEM manual show "system failed" it may concern transduceur or other part of the device...
On OEM manual it is shown that there is capability of connecting laptop with Device..
Did you do that...
Also there is shown • Multiple Alarm Functions can you have access form LCD screen to this mode..
It can give you more infos on what part is actually faulty...
I am sure that can help!
ControlsGuy25.
This is my prob, ihave 10 devices, all of them are down in same time, no manual, no program. What is the programNo password available from my side I am discovering that device ...
You bought that equipment without password..,? without documentation...without knowing actually how it should works
Thats a lot things that you need to do when you buying such equipment...
At least a thank you for your help/support can be envisaged ..
BTW fortunately this is an isolated case... people here are welcome for any issue to solve!
ControlsGuy25.
| A | ABB symphony harmony DCS BRC controllers | Distributed Control Systems - DCS | 0 | |
| A | ABB INSUM-OS | General Software Chat | 0 | |
ABB modbus need to help “ ABB water flow meter” | Modbus | 2 | |
ABB water flow meter Modbus FEX100-MB need to help | Sensors & Calibration | 4 | |
| K | Pump Level Controller ABB Datum U 100 | Process Control | 0 |
