Z
Dear Sirs,
I need some information about Capacitance Effect which is created in the end of transmission lines carrying AC power. My problem is as below:
The Stop/Start Switch (starter) is located in Master Control room located about 1100m. far away the electric motor. The level of the voltage is
440VAC. When we push the Stop button, the motor will not be stopped because of capacitance effect.
One way to solve the problem is to change the level of the voltage to DC.
I would greatly appreciate if someone can advise me any technical solution to resolve the problem.
Best regards,
Zare
Best regards,
Zare
