Hello,
I am student of Instrumentation engg. in V.C.E.T Vasai. My final year project is all about process loop control using DCS and PLC in master slave configuration.
As I said before my college is sponsored the DCS as well as PLC. We are using Honeywell HC900 (C30 CPU) as master and Siemens s7 200 (224 cpu) as slave with analog modules. As we are controlling level parameter of simple vessel we use modules for analog i/p (from level transmitter) & o/p (to I to P Converter). We are connecting pc (HNI) with DCS using MODBUS TCP/IP protocol via ethernet (straight) cable & DCS-PLC by RS232/485 cable. Both systems uses FBD. My question is all about is that possible to communicate between these two systems? If yes then How? Means what changes I should do in software setting while configuring for communication?
please give us your expert advise about this.
Thank you
Thank you
