Error message on Yokogawa DCS CS300
H
hua
after i dowmload to HIS, the system view display following:
equalize start .HIS1157
ERROE:processing terminated due to connection error (7002)
error=1 warning=0
has anyone see this error code before
Best wishes
hua
Jesus Carrero Blanco
Hello HUA,
Are you sure that is HIS1157 and not HIS0157?
Is your domain is 11?
Thanks.
I would like to make some basic questions. Are you sure the communications with this HIS is OK?
It seens like lack of communication.
It seems that ur V-net/VL-net connection is loose. Please measure / ensure 50ohms resistance between your V-net connectors inner leed to outer connector.
