what is duration for ignition timer of spark plug in gas turbine frame-5 during start up?
V Thread Starter vimal gupta Jan 3, 2011 #1 what is duration for ignition timer of spark plug in gas turbine frame-5 during start up?
3 309EGuy Jan 3, 2011 #2 For gas fuel K2FGAS is normally 10 seconds, and for Liquid fuel K2FLIQ is 30 seconds. I have seen these values used on Frame 5/6B/7E/9E turbines. If all things are working well flame typically occurs within a couple seconds for gas and 8-10 for liquid fuel.
CSA Jan 3, 2011 #3 The length of the ignition timer is dependent on the application and sometimes on the fuel being started on.
V Volkan AKIN Jan 3, 2011 #4 fire has to occur at most 30 second, otherwise it trips. but in generally you need 3-5 second to observe fire..
