G
Hi All,
I know this issue would seem to be discussed in other threads before but i really could not find an answer to my questions in threads i found.
Site have a GE frame 51P unit which only operated on Liquid fuel/Standard combustion system (non DLN). unit originally was been equipped with Mk II control system but two years ago it was been upgraded into MK VIe.
recently, unit tripped on exhaust over temperature while running on base load. we did checked the LF bypass valve manually by actuating it by air and we replaced the FD, servo VV, magnetic pick ups, welded FD to eliminate vibration and incorrect MPUs readings.
later we tried to start unit for more than once and it was tripping on fail to ignite or overtemperature.
GE was contacted and they did send a TA, he did change the null bias current (without following calibration procedures) he started with a default value then unit tripped on overtemperature, he changed the value and again unit tripped on Fail to ignite. lastly after the last change, unit started with no problem.
Truly, we spent almost over two weeks troubleshooting this unit as we tested almost everything (check valves, FD, LF Pump, Forwarding system, Filters,..)and TA only spent just 3 hours and solved it!!!!
Now i have some questions hopping that someone could kindly help answering it:
1. in such trips (over temperature and fail to ignite) when can one be sure that it is related to null bias current vale. how to be sure about it? what are the exact symptoms?.
2. in units like frame 51P that doesn't have motor driven hydraulic pump. how to calibrate/calculate null bias current for LF bypass valve????? i believe the followed try and error method is not a recommended one.
3. How could the null bias value have that much impact on the unit behavior?? we are talking about a very near values. i mean does a servo with null bias of 2.5 behaves totally different when it changed to 2.6???
Finally, your contribution is highly required and highly appreciated.
Thanks to all of you.
