HiHello everyone!
Does anyone know about the model used by GE for the primary frequency control of their GTs?
I have been digging around and have not been able to find anything on the subject.
Thank you always!
CSA,WTH???!!!?!?!!!
Are you expecting to control load to some setpoint during frequency excursions?
What do you expect Secondary Frequency Regulation to do?
What do you expect Secondary Frequency Regulation to do when Primary Frequency Regulation is active?
USUALLY, an ML (or MLI) has something to do with hardware (such as fuel nozzles or turbine buckets or gas fuel piping or conduit arrangements, etc?)--not with Mark* software options (though that might have changed since I quit working for the OEM).
https://www.nerc.com/pa/Stand/Proje..._Calculation_of_Reporting_ACE-D3-20150518.pdfCSA,
The original poster is trying to understand a system without actually knowing the basics of how thing work.
C | PLC WAGO read info of Omron (NJ101 and CJ2M) | Programmable Logic Controller - PLC | 3 | |
G | Contactor Info | General Automation Chat | 2 | |
J | Modbus Application Info | Modbus | 7 | |
M | Info on valve other than HART protocol | General Automation Chat | 2 | |
R | Packets of info being sent by PLC | Programmable Logic Controller - PLC | 8 |
