how can i interface wonderware to a delta v dcs system
P Paul Edwards Apr 21, 2010 #2 As with most things just Google "Delta V OPC". You will get a few hits. The one from www.rtx.com which looks like it may do what you want.
V vm karanth Apr 22, 2010 #3 Can u be little more specific. which is the control system behind wonderware that u r trying to connect to delta v
W Wassim Daoud Apr 23, 2010 #4 OPC is usually used for this. DeltaV has an OPC Server in it. You can connect it to the Wonderware system using OPC Data Manager: http://www.matrikonopc.com/products/opc-data-management/opc-data-manager.aspx Provided that your Wonderware has an OPC Server if it doesn't then you can ask Wonderware for the "FactorySuite Gateway" this is their OPC Server. Wassim Daoud Global Solutions Architect
