Hi everybody,
I am new here and this is my first new thread – let's hope I chose the correct category.
I am a junior employee at a company developing software for industrial automation. Recently the KNX protocol was implemented into our universal application platform.
My colleague (another junior employee) and I were tasked with creating a model application using the KNX protocol. At this point, it isn’t really for commercial purposes. It's more of a test project for us.
We created the application with a simple interface and established communication with several “smart home” devices supporting KNX. Since our platform is written in Ada, we had to use our own special module to use the KNX Falcon driver.
Now finally to our problem and question:
The application works relatively fine, we can communicate and read data from several devices, however, we encountered a problem with the MDT BE-GT2TW.01, Glastaster II Smart.
We can communicate with the device, but we cannot use it to control the whole system. If we for example try to change the temperature settings through our app, the panel registers it, but still works with the previous temperature setting that was done manually using the touch panel. The same process works perfectly fine for controlling the Led strips. Overall the setting of the panel is not working correctly.
Does somebody here have some experience with KNX, or specifically with this device? I understand that it might be hard to advise if you are not familiar with our platform and application, but do you please have at least some general idea of where the problem is?
Thank you.
Thank you.
