Greetings,
we had two lube oil pumps (vertical centrifugal pump, 7FA turbine) running @ the same time because if only one is working the pressure would decrease.
we have changed the pump with a new one, and the problem was solved. They didn't see any sign of damage or something suspicious when they opened old the pump.
I am not sure if they opened the part that is inside the red circle (see picture in the link), and I think the problem is inside this part.
https://postimg.org/image/wtjkkf9t3/
Any ideas?
Any ideas?
