F
Hi all,
I'm just an end-user trying to make a custom desk using some adjustable height legs I recently purchased.
The cables that came with the legs are 4' in length, and connect the controller box to the legs for up/down movement.
The seller is not capable of sending cables of the needed length and recommended that I have them made on my own.
Hopefully there's some help/wisdom here in getting these done correctly.
As I can best determine, the connectors are 6 pin MiniFit Jr 5557-6 Males.
I'd like to make either a longer version of this (Male-Male), or an extension version (Male-Female).
If I look into the connectors, I think I see wiring going to all six pins. This makes me think that the wiring setup used for these connectors is similar to the WTX 12V CPU (P4/P5) pinout:
http://pinouts.ru/Power/wtx12cpu_pinout.shtml
The cables I have in hand look much like this:
http://www.molex.com/mx_upload/family/minifit_overmolded__cable_assemblies/mf-overmolded_intro.jpg
I was also given this information regarding the controller and legs:
"Our control box has an output voltage of 31 vdc. The lifting columns have an input voltage of 24vdc."
So my questions are:
Is this the right place to inquire about how/where to have these cables made?
If not, do you have a suggestion on who to contact?
The WTX 12V CPU pinout has three +12v wires. Is this a match for what's needed to controller the legs, based on the specs I posted regarding the legs/controller?
Where should I go to buy these cables/have them made?
What specifications do I need to provide to have them made correctly?
Thanks so much, in advance, for your help!
Rgds,
flizit
Rgds,
flizit
