Measuring CT connections
panthripu
Hi
Can some one explain that what is the difference if we connect the measurment CTs in STAR configuration and DELTA configuration?
Panthripu... if the CT secondary’s are delta-connected, then how are the watt-meter 'coils' (or other measuring elements) connected?
Regards, Phil Corso
CT are to be connected to the transducer used connect them to PLC. Transducers are 0-5A to 4-20mA.
Panthripu...
Wye-connected CTs will properly yield the three line-current values, Ia, Ib, and Ic! However, Delta-connected CTs will yield the three vector sums, Ia-Ic, Ib-Ia, & Ic-Ib, respectively!
Regards, Phil Corso
