Do expect signal attenuation when the distance beyond 80 meter (again vendor specific)Hello,
Is it possible to run Modbus TCP protocol if cable lenght is 130-140m? It will work if I use cat6 instead of cat5? do you have experience with that?
There is always signal attenuation, the longer the cable the worse it gets. However all the vendors I have seen state 100m limit as attenuation is negligible up to this distanceDo expect signal attenuation when the distance beyond 80 meter (again vendor specific)
Would prefer to have fiber converter if it exceeds more than 50 Meters.
Correction. Baud rate is only for Modbus serial not for Modbus TCP/IP.Do expect signal attenuation when the distance beyond 80 meter (again vendor specific)
Else you have compromise on the baurd rate. Slower will work relatively better for longer distance.
Wonder why still modbus which is unsecured ? Why not Profinet or EtherCAT or something better?
