E
In our automation project, we are using Telemecanique Monitor Pro 7.6 Software and 3 Premium PLCs communicating with Modbus TCP protocol. If I configure Monitor Pro application with one PLC, everything works fine. But if I add second PLC configuration to Modbus TCP configuration, MBUSTCP process exists with error message: "CT file cannot be opened". When I look at the ct directory, mbustcp.ct file located there.
Can someone encounter the same problem or any solution idea?
Thanks,
S. Emre Sahin
Thanks,
S. Emre Sahin
