R
After a recent thunder and severe lightning storm my microwave oven stopped working; or I should say stopped heating. I'm quite certain that it took a surge. Everything I have read points to a varistor. I found it on the circuit board (it's an INR 10N471). There was someone on this site that had a similar problem and was advised to take it out of the circuit and check for an open or short; which I did. It read "open". Another person on this site said that it could read "shorted" which would mean it was definately bad, or it could also read "open" that could mean it was still good OR had been coupletely blown. From the little electronics that I received in the U.S.Navy, I figured that if it was already "open" then taking it out of the circuit and trying to operate the appliance without it, at least, would do no further harm. I plugged it back in and, sure enough, it still doesn't work. I THOUGHT I smelled a slight burning around the circuit board but it might just be my thinking the worse; I'm not sure.
My questions are, to anyone with more knowledge than the little bit I have: Should I replace it anyway? Have I likely caused more damage by plugging it in for a short while with the varistor out of the circuit? If it read "open", then it was really out of the circuit anyway, wasn't it? I can see no visible damage anywhere on the board and am lost.
I am leaving on a trip with my wife in a couple of days and any help in getting the thing fixed before then will avoid the dirty looks I'm likely to suffer until we return!
Thanks, [email protected]
