Dear Sir,
We have one AB Compact Logix Processor, and one tOUCH Screen panel View 1000 Plus, as the system is working fine.
As we have Hub between the processor and the HMI Panel View with the UTP Cable Length 2 meters only.
As we like to install one more touch screen in the ground floor, which is away from the hum from the distance is 50 meters.
When i use 2 meters straight utp cable, i am communicating well with the both the HMI's, and when i am using 50 meters cable the new HMI is not communicating. We checked the cables well, and not fixed the problem.
Please advise us AB PAnel View Plus 1000 have any limitation on the LAN Network Cable or not. If i am right it should comminicate well less than 90 meters as we are using UTP Cable.
Please suggest me the possible solution.
It would be grate forum memebers comment on this problem.
Sony Philip
Sony Philip
