I have a query regarding a programming problem in Yokogawa Centum VP.
I want to make a program that gets numerical input from the 'Operator' thru HMI and uses CALCU block to make some SEBOL calculation and then shows the result on the HMI. For user/operator input numeric value I am using MLD Block. But the problem with the MLD block is that it cannot take value larger than '100' and less than '0'. Kindly guide me, what function block or method should I use to get any numeric value (signed/unsigned) from the user/operator and get it utilized in CALCU block formula.
