PG 750
Molaei
The matter is that We used PG 750 in our power plant that was connected to Teleperm ME system. But now PG750 is out of order and we have to change it with some new PG. The replacement that we found is PG M2. The problem is there were 2 softwares as below which worked in this connection between PG750& teleperm.
software AS220EHF OP250 PC VAR.D(E) V6.00 6DS 5208-8DB
software AS220EA STRUK-AS220 EA(D) V6.00 6DS 5221-8AA
Now I don't know PG M2 is matchable with Teleperm ME system? What should I do with these softwares? I couldn't find these softwares anywhere? orPGm2 doesn't need these softwares and it can be connected with Teleperm ME by itself.
I wish I could explain good enough to convey my problem. Looking forward to hearing from you.
Best Regards,
F.Molaei
Sadra Sanat Co.ltd
alex olokhtonow
Are You using TTY interface for TME connection or only NAT? In case of only bus connection You can use any available PC with newer NPCI card, which You can order either from Siemens PG, now EI, or AND. I have not used OS250PC but STRUK is all right
