Hm...curious. The only explanation I can think of is that one of the wires in the Ethernet cable was either broken, making only intermittent connection, or the wire was not making good contact to the Danfoss device's terminal (for example, only on the insulation, not the conductor).
Of course, without knowing for sure, there's always a possibility that something else changed without you realizing, and whatever changed may change back again in the future, causing communications to fail again. It's for that reason, I always like to confirm the suspected root cause of an issue is indeed the actual cause and not simply a coincidence or partial cause.
