Dear all,
I am planning to replicate a relatively simple experiment, but I have no prior experience in temperature measurement and control. I would like to manage it on my own, but I would appreciate any advice you can provide (even just to avoid unnecessary expenses).
As you can see from the attached image, I need to immerse the PT100 in distilled water or glycerin, which can reach temperatures up to 300°C. The required accuracy is around ±1°C. Additionally, it is specified that the PT100 should be calibrated for an immersion depth of 40 mm.
I have started reading through several datasheets, but I feel like I am missing something in understanding the specific requirements that the PT100 needs to meet. Could you kindly share any advice and perhaps suggest a website where I can find some cost-effective options?
Furthermore, I need to heat water to reach the desired temperature at a specific °C/min rate.
I was considering purchasing this component:
https://www.tcdirect.co.uk/product-...er-with-up-to-4-Set-Points-and-Timer-Function.
However, I still have a few questions:
Best regards,
- Obviously, I need to purchase an electric heater capable of bringing the water from 0°C to the desired temperature, and sizing this is not a problem for me. However, I am unsure which type of immersion heater would be suitable for my purpose. What characteristics should it have?
- Will I be able to directly connect the heater to that PID controller, or will I need an additional component?
- Do you know where I could purchase an immersion heater like the one in the attached image?
- If I want to generate a data plot on my computer, will I need to purchase an additional component? If so, which one?
Best regards,
