P
I have purchase some AB drivers from VHMI automation and can not get Phil Covington to respond to any questions for support. From his personal site it seems he has moved to Romania. Anyone else having better luck getting him to respond?
It seems his drivers do not adddress SLCs by slot address for Inputs and Outputs. The Inputs and Outputs show up as one continous block of data whether Inputs or outputs are in order or not. If there is in input card in slots in 2,4,6,8 and you request data file 1 and start address 0 you will get data from slot 2 and if you request start address 1 you will get data from slot 4. Any way to get to a slot directly using his drivers? Also there seems to be a problem if you use both DF1 and ethernet drivers in the same VB application when writing to a PLC register. Anyone else have this problem?
