Auma Actuators AC 01.2 which are failing to bootup with WD-Timeout error
Check all wiring and connections for any signs of damage or loose connections. A short circuit or improper connection could cause the actuator to fail during boot.
We were able to get a firmware update from Auma. You need to send the serial number of the MOV that is failing then you can download the files and put it in your flash drive. The problem why it did not work the first time was because the files that I originally had was not really for a firmware update. So, even if it does not boot, it will actually get the update from the flash drive once you insert it (need a reboot to be able to detect).
Hi superbullet can you email me the firmware that you have? because AUMA didn't answer to our mails and i didn't found any firmware to download
thanks
[email protected]
MWG error will appear if your position module is faulty or has a loose contact. If, after you tried to clean and still showing MWG error, then you have to replace the module. For comm lost, is this a fieldbus device or hart?
Have you gotten any firmware ?
Good day.
Can somebody help me to find the Updated Firmware of Auma AC 01.2? I tried to ask from Auma but nobody replied.
Greetings,
Do you have any firmware update file for Auma Ac 01.2 type.
My email: [email protected]
Thank you in advance,
hello my friend do you have any firmware update file for AUMA AC 01.2 type ?
please sugest soloution about atteched.
thanks
Asad Ali
[email protected]
thanks
[email protected]
hello
my friend do you have any firmware update file for AUMA AC 01.2 type ? if everybody have it please share or send it to me, my Email Address is: [email protected]
thanks
Link for Auma Actuator AC 01.2 firmware v06.08.02
https://drive.google.com/file/d/1605WOReA7jystc9g0204kFaQIJXkP_Rm
